How much transmission fluid requires
smoothgroove, Sep 29, 6:48pm
Where do I go to find out how much gearbox oil I need, when changing fluid in Subaru STi (V7)!
twink19, Sep 30, 5:50am
ask mr google
intrade, Sep 30, 7:20am
depends dont just changefluidsdrop the sump and do it propperly . automatic trans rebuild places sell sumpgaskets and filters cheap enough be like 10 bux gaskitand 25 to 45$ for the trans filter and then you want about 12 to 15 liter trans fluid . make sure to use correct fluid i would guess but not sure that it runs dextron3 on it.
You might have a fight with the original gasket they are factory glued shut with goop. takes a long time to clean the crap best done on a car hoist as you got to work absolut clean no crap inside trans after you finished.
intrade, Sep 30, 7:24am
you flush it by disconnecting the return of the trans-cooler after you changed the filter and sump gaskit fill up 4 liter in trans and fire the car up till clean fluid comes out on return . easy as to flush most automatics but best done on hoist and its usually gona get messy with more fluids apearing when you remove a partial blocked filter all fluid comes down what was above the filter.
If you cant do this then get it done professionally. Some need adjusting on bands also some dont .
smoothgroove, Oct 4, 4:08pm
It's an STi Subaru.
manual gear box.
can't find it on Mr google.
intrade, Oct 4, 5:34pm
manual trans either got a dipstick or you fill it till oil pours out the filler hole half way up the gearbox , should be slight below filler half way but wont matter i always fill till it pours out and then shut the plug.
intrade, Oct 4, 5:37pm
jinx317, Oct 4, 5:41pm
5 or 6 speed!
5 speed is between 2.5 & 3.5 litres
smoothgroove, Oct 5, 8:41pm
6 speed STi box
