Driver side window just popped out, jammed now!
nunesy, Oct 4, 6:50pm
The window has been only winding down a few inches, but tonight when I wound it down and then back up it popped out of it's place and is now at a 45 degree angle pointing into my car. ie it's attached at the bottom but that's all.This is a job for an auto electrician, right!
gunhand, Oct 4, 6:54pm
Yes and no, panel shop, sensable mechanic or auto electrician should be able to do it, You could prob do it yourself, some are very easy and some are a pain. Its come out of its holder on the bottom most likely. But you have to putit all in correct place to make sure it works properly.
And of course a glass outfit as well.
