Any one know how to regulate/ajust the Oil flow and the plug gap please !
bmc460,
Oct 2, 5:29pm
The oil pump is in behind the front sprocket.Coming out the top is the cable,you just adjust that for oil.Screw it in for less oil or out for more,it regulates how far the lever gets pulled on the pump.
robinm1,
Oct 2, 6:01pm
To expand on the last message, have a look on the side of the carb, about 1/2 way up there is a small hex plug. remove that and slowly turn the throttle, a mark on the carb slide will appear in the hole. When the carb slide is in that position, the line on the oil pump cable attachment should line up with another mark on the engine casing. When both sets of marks line up at the same time the oil pump is correctly adjusted. Spark plug, NGK B7ES or NGK BR7ES.8mm (about .030")
luigi21,
Oct 8, 8:12pm
x1
Thanks Cheers
luigi21,
Oct 8, 8:12pm
Many thanks Cheers.
mbikeman1,
Oct 9, 7:17pm
yup what robinm1 said is correct
