Nissan elgrand. Driving along and the van just stopped the engine just turned off the lights were still working i had to tow it
delboy84,
Oct 21, 3:46pm
Driving along and the van just stopped. The engine just turned off the lights were still working i had to tow it home. I changed to fuel filter but it is still not starting any ideas on what could be wrong. I checked all fuses but all is fine
Oct 21, 4:18pm
what engine!
delboy84,
Oct 23, 12:33pm
qd32 diesel turbo
chebry,
Oct 23, 12:36pm
Have you checked the useby date!
shane191,
Oct 23, 4:15pm
you ran out of fuel lol
Oct 23, 4:21pm
Do you use a dieselfuel additive!
Oct 23, 4:39pm
you crack the injector nuts and crank it over you should get fuel there if not then you either got a fuel-shut silanoid that has no power or the silanoid it self is faulty, you can just remove the plunger and then it wont stop unless you stall it not possibile on a automatic so you would have to undo all injector nuts while it runs to stop it . If it still dont gets fuel on injectior with all nuts loseand no shutof plunger on pump then you probably have a seezed injector pump as even with air in the system you will get diesel there unless the (ip) is broken.
Oct 23, 4:50pm
Oh no! Not this again!
arrithedog,
Oct 23, 7:40pm
It's times like this you wish you'd joined the AA.
