Removing oil seals scooter forks
glyn4, Oct 21, 4:28pm
Hi, I have an Suzuki FS50 with leaking for seals. It has small tele's like a pit bike. Tried to remove the old seals today but there seems no way to remove the internal damper rod/springs so as to access the seals. There's no grub/screw/bolt at the base as in larger forks. Will a good engineering company be able to do this! Anyone recommend someone!
mechnificent, Oct 21, 6:12pm
There might be a top dirt seal which you can pull off, then there will be a circlip, remove that and then use the shaft like a slide hammer to pull the oil seal out.
