Fog light question
night88, Oct 24, 12:07pm
I have an older car (late 80's) and one of the fog lights is damaged and needs replacing. They are a sealed unit and a nightmare to replace (and not cheap either) so I would like to permanetly remove both as I never use them anyway.
My question: is this legal and would it pass a WOF!.
Thanks in advance.
splinter67, Oct 24, 12:11pm
yes you can take them off but if they are on there they must work
chook90, Oct 24, 1:01pm
+1. There is no requirement to have them however if you do have them they must function as intended.
night88, Oct 24, 1:04pm
That's good news. Thanks.
splinter67, Oct 24, 1:08pm
no worries make sure when you take them out that you wrap the wires in insulation tape so they dont earth out and cause other problems
night88, Oct 24, 1:41pm
Will do. The wires are actually soldered into the lamp and need to be unsoldered to be removed as compared to the headlights which use a socket and are easy to take out.
