Needing to replace the lifters so thinking I will put a hot cam in.
What im wanting to know is will I have to change anything else like the ecu setting. I have never done cam mods on a non carbed car before, really old school here
bellky,
Nov 7, 9:49am
i think if it has a maf sensor then all will be good
i know the injected 5.0s are like this (i have one)
thegravelracer,
Nov 7, 1:17pm
lol dips4i7
unbeatabull,
Nov 7, 2:10pm
You will notice a small increase with the cams, but to get maximum benefit you really need a ECU Re-Map/Tune
1fordluva,
Nov 7, 4:59pm
what model of falcon! If it is a newer model it will have no bearing bar crappy idle and bogging down low. if you are going to do the camshaft,you have to remapp or flash a suitable tune to the ecu. Have seen a few people try this and fail,because they havnt done sufficient homework. Injector duty cycle will be fine if it is a v8. but this is pointless without a tune to suit camshaft upgrade.
v8_mopar,
Feb 8, 3:51am
Its a xr6 ED. They are only 164kw so low on take off power
#3 I must of stole my misses to ;)
