hi there ive wired up some jvc 310 watt 6x9s andwired it to the four channel amp.was wondwering why its just bass and no voice
bitchwitattitud,
Oct 31, 4:34pm
Have you connected to the right output on the amp! mix settings on headunit!
ckandsj,
Oct 31, 4:42pm
There should be a switch on the amp for LP (just bass for subs) Hp (just high and treb for front speakers) and FULL ( full range) FULL is what you want it set to for 6x9s
dunedin_moto,
Oct 31, 4:43pm
Sounds like you have the filter switch the wrong way round.is it switched to low pass perhaps!
inkapuka,
Oct 31, 4:59pm
i will ad pics to show you
inkapuka,
Oct 31, 5:16pm
uploading a pic of the other side the thin cables are 6x9 are the ones with red connector bit on them. black thick is sub
inkapuka,
Oct 31, 5:18pm
sorry woosh is slow lol
ckandsj,
Oct 31, 5:18pm
see the switch is on LPF thats low pass filter which means it will only play bass switch that off and you will be sorted
dunedin_moto,
Oct 31, 5:20pm
Do this.
ckandsj,
Oct 31, 5:22pm
You cannot run it like that you have to have the rear channel for the sub and the front channel for the 6x9s. This means you will have to get some splitters for your rca's so you can plug them into the front to
inkapuka,
Oct 31, 5:22pm
sweet so iv'e got it wired up right! i used to only have a mono channel it only had sub.Nowif wanted to wire up sub since it's dual coil where would i put the other wires for that!
dunedin_moto,
Oct 31, 5:23pm
Jesus.
inkapuka,
Oct 31, 5:23pm
ill try it now and see it that works
ckandsj,
Oct 31, 5:23pm
Leave the black sub wires where they are and move the 6x9 wires up to the line above where it says front.
inkapuka,
Oct 31, 5:25pm
what im just trying to save coin to diy and learn so i dont have to get someone else to do it for me
dunedin_moto,
Oct 31, 5:25pm
Did you read any of the info on that site I posted the other day!
inkapuka,
Oct 31, 5:26pm
do i need anothe rca lead to do that
dunedin_moto,
Oct 31, 5:26pm
And good on you too. But you should ask before you DIY:) I have posted some info in the past for you and have others but judging by the pictures you havent paid any attention. No offense intended.
dunedin_moto,
Oct 31, 5:28pm
Yes you will. How many outputs does your head unit have! Other option is using a splitter
ckandsj,
Oct 31, 5:29pm
Yeah or you can get little splitter leads that that go from one pug to two. You plug one on the right then plug those two to right front and right rear do the same for left
inkapuka,
Oct 31, 5:30pm
ok just tested it with it set too off and its less bass and i think i can hear voice but not noticeable
dunedin_moto,
Oct 31, 5:30pm
Or just run your 6x9s straight off the head unit.much easier. Better to amplify a set of decent front speakers than any rear speakers.
inkapuka,
Oct 31, 5:31pm
my headunit has 2 rca
inkapuka,
Oct 31, 5:33pm
i have sony 3 way in front doors 2way in rear not sure in power rating but not commponent
inkapuka,
Oct 31, 5:33pm
any on trademe you can show as an example so i know what you on about!
