I'm going to build a 8x4 trailer for home, can't decide what to use for the floor, what is better plywood or steel! any other ideas that might useful!
msigg,
Nov 8, 5:58pm
treated ply will last forever, steel will rust.
mokaubach,
Nov 8, 6:04pm
1 x sheet of Ali Chequer plate, 3M tape it to your cross members for no fastenings, superb deck.
dr.doolittle,
Nov 8, 6:09pm
Until you use your shovel to get every bit of builders mix out. Just use 25mm ply, should last forever if you throw a $10 Warehouse tarp over it when you're done.
plasticboys,
Nov 8, 6:17pm
plywood is better things you put on the deck move to esay with steel
pdc1,
Nov 8, 7:33pm
Those big signs on the side of the road are great. Wof guys always laugh when the see the writing underneath
skull,
Nov 8, 7:41pm
Marine ply went onto my home made trailers, about 25mm thick. The one I kept lasted more than 25 years and was still in good condition when I sold it.
dave653,
Nov 9, 8:04am
Ply is a hell of a lot cheaper than steel. Exactly the reason I'm going ply.
