hi can someone tell me plz if ya can adjust the clutch cable on a chariot like you can with some other cars!if so is it easy to do!thx
Nov 11, 9:36am
normally on gearbox leaver if its manual clutch cable is the adjustment on most cars. non adjustable if hydraulic
Nov 11, 10:33am
What's actually wrong with the clutch! Is the pedal staying stuck to the floor! Or is the clutch slipping (engine revs a lot but going nowhere)!
caitlin34,
Nov 11, 10:40am
clutch jumps out of place or grauches when changing gear
Nov 11, 10:43am
Does the clutch pedal feel normal!
Nov 11, 12:02pm
sounds like your gearbox is rooted , and has rounded of gears. Dont waste your money on a new clutch as that is not the clutch problem that you just discribed.
Nov 11, 12:03pm
grauches when change of gear would likely be synchonous rings worn . if its to do with clutch it would do this on all forward gears the grauching.
phillip.weston,
Nov 11, 12:24pm
I'm pretty sure you will have a hydraulic actuated clutch rather than a cable. I would start by checking the clutch master and slave cylinders.
