What can I use besides Honda's CVT transmission fluid for an EK3 Civic!
Nov 20, 9:38am
the transmission does not need topping up the transmission does not consume fluids . if you think fluids are missing then you probably simply dont know how to mesure the level. only reason for topping up is leaking transmissions. and they will be a spcial fluid .
greateft,
Nov 20, 10:46am
Hey mate, good to see you still 'round here. I'm replacing the fluid - CV boots are split and on these you've got to have the whole axle out to replace them - draining the transmission first. It hasn't been changed in about a decade so I reckon the opportunity's there for a flush.
Nov 20, 11:05am
change filters and do correct proceder . the toyota corolla i just done has a seperate diff compartment i would ring a automaitc trans rebuild place for parts and howto. if you cant find anyadvanced automatics whangarei can tell you all you need to know and sell you parts .
For expert advice on this, try Honto Motors in Penrose. Asian chap who is an expert on Hondas, we take all ours there.
kevymtnz,
Dec 6, 10:19am
lol my nissan belt i can get from oz for $200 less
