abs light stays on after starting car have read in ford forums that this is a common fault and can be fixed by earthing a certain pin on diagnostic plug and will reset , havent tryed as was unsure . any input would be greatly appreciated
unbeatabull,
Nov 25, 6:54pm
If there is nothing wrong with the ABS system you can reset the codes by earthing two pins together for 10 seconds. I can't remember the pins off the top of my head sorry, but pretty sure its top left and bottom left.
If there is actually a fault though the code/light will come back up.
aje11,
Nov 25, 7:03pm
remove dash and take bulb out
unbeatabull,
Nov 25, 7:04pm
Great idea, then when your brakes fail and you crash.
sabbath-black,
Nov 25, 7:07pm
.when they do a w.o.f check it wont come on, so fail
becsr1,
Nov 26, 6:19pm
yeah not taking bulb out just thought maybe there was a reset for it
justcruisin,
Nov 26, 7:31pm
fordmods.com have a tech page for this
beast9,
Nov 26, 8:04pm
bent rims warped disc rotors or even a crook wheel bearing can cause this fault as well
meathead_timaru,
Nov 27, 9:26am
ABS fails safe. The brakes will still function just as non-ABS. The light is there to indicate that the ABS itself is not able to function at that point in time.
