tickets for noise. Cracked pistons lack of power Thirsty Go deaf AND probably get a beating from the locals Get it pinched by some yobbo BR (cause it sounds 'sick' chew through spark plugs
theram1,
Nov 27, 12:10pm
It would suck, imagine the noise it would make, what ever floats you boat.
andrea_w,
Nov 27, 12:11pm
Absolutely nothing if it's electric
theram1,
Nov 27, 12:14pm
Even less if it is diecast.
aleestar,
Nov 27, 12:15pm
my mate wanted to no lol
andrea_w,
Nov 27, 12:18pm
Ah so now the flaming has begun, the car is now not yours eh .! What car does your "mate" have!
aleestar,
Nov 27, 12:25pm
a 5.0 vr ss
theram1,
Nov 27, 12:28pm
A mate with a Holden my god tell him that it sucks and to straight pipe it, wouldn't that be the best thing for it.
aleestar,
Nov 27, 12:30pm
cool sweet thanks
meathead_timaru,
Nov 27, 1:53pm
Nothing except the admiration of by-standers. You go for it, kiddo!
jason18,
Nov 27, 1:54pm
It will sound boss as man!
Nov 27, 2:00pm
straight pipe means that the tiny little men with hammers can crawl up the pipes and attack the piston crowns. Then their brothers with blow torches will try very hard to melt the pistons. Before you think this is a joke -go to the LIBRARY. funny building with slabs o9f paper in em called books.look up race tuning a holden or even just basic internal combustion. See if you can work out why its actually NOT a joke
poppajn,
Nov 27, 2:38pm
No WOF; even raceing car,s have a decibel limit.
trademerob,
Nov 27, 2:55pm
While i think the above is a wind up.I raced a big bike for years with a straight pipe higher compression than a car and it when,t faster as the years when by.
wrong2,
Nov 27, 3:05pm
but your post is a joke
not having a muffler wont kill your engine
look at the Supermarine Spitfire - they didnt even have a proper exhaust length & ran 28+ psi . . . . . .without mufflers
bellky,
Nov 27, 3:06pm
^Yep, same for some of that mrfixit garbage up there too.
tgray,
Nov 27, 3:10pm
Just change the rear muffler.
Nov 27, 3:14pm
How long did those engines run for ! were they running efi with limited adjustability
mrfxit,
Nov 27, 3:18pm
Those engines would not have been factory std engines with straight pipes & as for the Spit Fire engine, thats a dedicated aircraft engine designed to run with short pipe stubs
LMAO "mufflers on an air force war time fighter plane" ;-)
wrong2,
Nov 27, 3:20pm
oh please!
aircrafts cant just pull over if the engine dies
mufflers are there for the noise. not the longevity. if your running the right length & jetting, the only difference will be the noise
lordv81,
Nov 27, 3:22pm
28 PSI! The British measured boost pressure as lbs./sq.inch (or psi). The normal atmospheric pressure at sea level is 14.6959 psi, although this can vary from day to day: a reading of +6 meant that the air/fuel mix was being compressed by a supercharger blower to 20.7 (rounded figure) psi before entering the engine; +25 meant that the air/fuel mix was being compressed to 39.7 psi. However, there was a problem with the British system of measuring boost, in that in an aircraft the pressure gauges should measure absolute pressure within the engine's supercharger, rather than showing atmospheric pressure at sea level, plus the supercharger's pressure; at sea level this was a reasonable measure but, in engines that were used through different altitudes this method becomes completely arbitrary. Because the Americans measured their boost ratings using inches of Mercury (" Hg), their boost gauges more accurately recorded the absolute pressures being generated by the superchargers at all altitudes.[13]
lordv81,
Nov 27, 3:26pm
An old drag racers and motorbike owners way of judging where to cut exhaust/headers was to paint them and cut where the paint was not burning.this stil gave back pressure and performance as it showed where exhaust gasses were the coolest.Still stuff your engine in the long run especially if not tuned to run richer for short periods.
