Random starting issue 2004 1.8 1zz-fe Motor
jason18, Dec 21, 11:51am
Cold/ hot whatever. Cranks over for about 5-8 seconds before it starts then leave it for 5 mins does the same. Turn on then off then on again it starts fine. Give it 5 and back to long crank. Coughs a little when it does it. Throwing no codes,,,, New plugs in. Any thoughts!
gadgit3, Dec 21, 11:53am
Air fuel ratio sensor. Bank one sensor one heater curcuit fault.
jason18, Dec 21, 12:33pm
Would that show on code! Obviously you have come across itt before ! Thanks
jason18, Dec 21, 12:42pm
So i get new air fuel sensor and i should be away !
intrade, Dec 21, 12:52pm
i would start with fuelfilter change
gadgit3, Dec 21, 12:58pm
Hay Jason check the resistance between the two black wires of the first sensor before the cat. If there is non then there is the issue
jason18, Dec 21, 1:15pm
Awesome mate. Will have to get a multi metre
jason18, Dec 21, 3:46pm
Cant get to where the plug is located! Does it go through the drivers side floor!
