RA1 Odyssey Dead
panelvanner, Dec 23, 9:46am
Just started switching off randomly, restarting each time, until it became hard to start. Now it is dead in the drive, will crank, just not fire. I fitted a used ignition switch (but from a later model one - looks the same, same markings and wires etc. - cut and soldered) as I had come across that before, in an Accord. Annoying, it is sitting with a full tank of gas. It has the 2 and 3 pin obd plug, under glove box, bridged the 2 pin one, but only brought up an ABS flash code, 21. I went to dub dot Rennacs diagnostic site, and code 21 says V-tec solenoid or circuit, but ours is only 2.2 non Vtec. (And this was still only ABS light). I am not sure of which pins to bridge on the three pin plug
Help appreciated anyway.
All the best.
Panlevanner
llortmt, Dec 23, 9:58am
Main relay or ignitor in distrributor
doug207, Dec 23, 9:59am
I'd be looking at the dizzy on it for a start. They can be quite problematic
howz_that, Dec 23, 10:09am
start with the basics. Do you have spark and fuel
panelvanner, Dec 23, 10:15am
Fair call, I had not looked at those yet.Just they usual Kiwi way, you know, assume, then fix before testing!
panelvanner, Dec 23, 10:52am
Hi and thanks, to all. Have checked for spark, wifey cranked while I checked, spark ok at #1 lead with a dummy plug, but could still be random spark/confused dizzy etc.
I would be surprised if fuel was the issue, as no warning (surging etc) was given whenever engine stopped. Just a straight stall, at any rev/load combo.
clark20, Dec 23, 11:03am
http://www.youtube.com/watch!v=viIZ8k60awY
Main relay common problem
llortmt, Dec 23, 11:05am
Check for fuel to the rail, (which there will be) then throw a distributor on it.
panelvanner, Dec 23, 12:09pm
Cheers Guys. I will let you know what i find.
Panelvanner.
kazbanz, Dec 23, 2:08pm
sorry to repeat the odvious -go back to basics.-The engine needs spark,compression,air and fuel.
Is any one of thoise missing!
Im thinking you might yhave a totally blocked up fuel filter.Or a worn dizzy,
llortmt, Dec 23, 3:41pm
Fixed!
