My car stutters and rings out in first gear. Once going the car is awesome. It diesnt do it all the time and only does it when its warm. After a HUGE amount of googling the matter and seeing a couple of mechanics with different ideas.nothing seems to add up. Sensors, solenoids, valves torque coverter Any suggestions!
Dec 26, 3:10pm
whats the colour of the trans fluid!
mopar06,
Dec 26, 3:26pm
new. Just had the whole flush/change.
Dec 26, 3:48pm
What year is the Odyssey!
mopar06,
Dec 26, 3:50pm
2002.the troublesome year so i read.
Dec 26, 3:51pm
What happens when you take off in 2nd gear and work your way up!
Dec 26, 3:51pm
was it propperly done sump off and new filter etc!
Dec 26, 3:52pm
Odyssey transmission hasn't got a sump or a servicable filter.
mopar06,
Dec 26, 3:57pm
Auto automatically changes to first gear when you come to a stop, even in the manual tiptronic mode. If you were able to take off in 2nd you would be able to apply full power with no slipping.
Dec 26, 4:02pm
well i would not be so sure if i was you Transmission Filter Genuine Factory Honda Odyssey Automatic Transmission Filter. Note: this filter may not be easily accessible without training and professional tools.
If it was a faulty solenoid, the problem would be there all the time. Transmission ECUs rarely play up, but would pay to check it out first. If the fault occurs only when warm, then I suspect it's got a mechanical fault = tranny out job. Also, they need to use the correct type of oil, allow $2000 to $2500 for a rebuild.
I recommend you get it looked at by professional automatic rebuild place. some use special honda fluids only also wrong fluids willdestroy the transmission.
Dec 26, 4:13pm
There is a filter (or should I say, a strainer) inside the transmission. The casing needs to be split to get to it, which would involve a transmission removal, and no, you don't want to do that. It does SFA anyway. However, the drain plug has a big magnet on the end of it, which picks up enough crap as it is. I do a drain and refill on mine once a year, 200k so far and no problems at all. The V6 Odyssey has got the worst rep for eating autos.
Dec 26, 4:18pm
i usually just ask my automatic specialist and get the instructions from him, and thats where i be taking thecardont know any good places near napier.
_frodo_,
Dec 26, 4:18pm
Bare in mind that is a USA site, and USA domestic odyssey which is different to the ones we have here.
mopar06,
Dec 26, 5:34pm
Crap. Looks like it will be a dealer trade in for whatever I can get!
