Ford D series how to unlock cab so it tilts
etimret, Jan 19, 7:58pm
Hi im trying to tip the cab on a ford d series . I know its easy but ive never done 1. I pulled the lever on the side to unlock but it still seems to catch on something. So i walk away instead of wrecking something. and ask for HELP
theram1, Jan 19, 8:05pm
I think you need to rotate the gear lever.
mercbens, Jan 19, 8:06pm
From memory - you have to turn the gearlever around before you tilt the cab. There is a latch at the rear of the cab and I think a safety latch by theback of the left front mudguard.
it's been a while since I did one - hope this helps
sas777, Jan 19, 8:11pm
Agreed, the latch thing inside the cab can be very tight, depends if a gorilla tightened it last.
Don't forget to clean out the stuff behind the seats or you could bust the windscreen.
etimret, Jan 19, 8:15pm
thank u will test tomorrow
frog73, Jan 19, 8:40pm
From memory __in side the cab in the center at the back is a lever lift up and unscrew. the one on the outside is the safety catch
mechnificent, Jan 19, 8:47pm
What he says.
sandypheet, Jan 20, 7:42am
Wouldnt mind a dollar for every time I have tipped one of those,#3 has it right.
elenor, Jan 20, 8:02am
bloody heavy by yourself
robinm1, Jan 20, 8:52am
A lot easier to tip if both doors are open.
skin1235, Jan 20, 11:39am
lol, I recall well a slightly built young apprentice that did that, and managed to get his overalls caught on something, he was 3 ft off the ground, absolutely helpless, as we were from laughing, the photo stayed on the wall till he qualified
