Sagging in rear end help
nattypoo, Jan 29, 9:47am
hi there i have traded cars with a mte and have noticed the rear end has sagged does anyone know wht it is! its a honda oddessey
kazbanz, Jan 29, 10:09am
What do you mean sagged! --sits low or the metal has bent !
nattypoo, Jan 29, 10:12am
it sits low, lower than the front when i have no load in it.
bellky, Jan 29, 10:22am
It could be designed that way. (Not very likely)
The springs could have sagged. (Not unlikely)
Someone might have modified it to sit like that. (Most likely of the three imo)
nattypoo, Jan 29, 10:26am
so how do i fix it it also bounces a lot over bumps
splinter67, Jan 29, 10:35am
New shocks and maybe new springs
franc123, Jan 29, 10:46am
Import is it! Most of them are set up all wrong for NZ and the factory springs are generally too light and will sag relatively quickly under local conditions, simply what happens when you buy cars made by and for runts. The likes of King or Cobra should be able to supply a good replacement.
nattypoo, Jan 29, 10:48am
have rung the shock shop and they can run a est for me. how hard is it replace springs and shocks!
bellky, Jan 29, 11:21am
It's a job you can do yourself.
pico42, Jan 29, 1:10pm
What local conditions are that different to where the vehicle has come from!
_drdee_, Jan 29, 1:49pm
I take it you don't drive a car made by these 'runts'!
gsimpson, Jan 29, 3:12pm
Sagging rear! Try one of these Listing #: 557506346
rovercitroen, Jan 29, 3:16pm
LOL. Wife has that problem and she's an import too!
sr2, Jan 29, 3:21pm
LOL; and here I was resisting the urge to make saggy rear end jokes!
franc123, Jan 29, 3:43pm
Erm, carrying two or three or even five beefy kiwis in the back, or beefy anyone for that matter, trailer towing, being used on rougher road surfaces that make the suspension work harder. The answers are obvious I'd have thought.
arrithedog, Jan 29, 3:50pm
Have you ever driven in Japan!
pico42, Jan 29, 4:33pm
Obvious! That's the thing, I have often heard about cars not being suited to "NZ conditions", but the more I see of some overseas roads (and i cannot vouch for Japan) the less obvious it becomes and the more I question this assumption.
Are NZ new versions of these same vehicles outfitted differently when it comes to suspension! I mean for normal mostly urban, some travel type use, not the "high country kit" type upgrade for a particular heavy duty purpose.
pnh4, Jan 29, 7:00pm
was it always that way, when you got car,
