The Hazard sign (triangle and circle) is - Traction control off
fiatracer,
Feb 28, 8:30am
perhaps it has blown a couple of fuses - traction control and something else, or a fuse and a bulb.
hpaul,
Feb 28, 8:34am
Yep - yellow one's traction control light warning, but as it's only a 318i it shouldn't cause any wheelspin issues ; )
kukimonster,
Feb 28, 8:43am
thank you all so much.The other warning light!The red one. any ideas!
fiatracer,
Feb 28, 10:00am
if you mean the 'door open' warning - either a door isnt closed, or something is wrong with the mechanism - perhaps the little switch [that is on or off depending on door being open or closed] is damaged
haventrader,
Feb 28, 11:17am
Could well be you've blown a lamp. If the terminals are a bit dirty and the connection not good, it would show the same.
kukimonster,
Feb 28, 11:38am
Doors are all closed, will check if anything in the boot around the clip.Usually when the door is open, the little lamps around that warning light are not normally on.First time Ive seen the 'lamps' around the warning light.Thanks haventrader - will check that too.Thanks everyone for your advice.
therafter1,
Feb 28, 1:09pm
By lamps I think the poster means bulbs, as in tail stop, position etc.
bmwnz,
Feb 28, 2:56pm
To us electrical types, 'lamps' is the preferred correct terminology.
footplate1,
Feb 28, 3:40pm
The yellow one is an ABS warning lamp.But it may only be a circuit issue.But, in case it is a sign the ABS system has failed, I would have the car checked.I had mine checked twice in my previous 330 and it was not the ABS system.Whew!
MIght as well get the other checked at the same time.Just be hopeful it is not the whole display system - I had to have mine replaced three Beamers back.
monsieurl,
Feb 28, 5:12pm
I'm sure you were meaning three Bimmers back ;)
@ the OP, visit bimmersport.co.nz you will get all the help with your BMW you need.
ola_bitchola1,
Feb 28, 5:27pm
bulbs are for planting in the ground as my boss said to me when i was and apprentice
therafter1,
Feb 28, 5:40pm
10, 12 and 14
The I??
monsieurl,
Feb 28, 6:14pm
1001% + 1 ^^
doug207,
Feb 28, 6:26pm
The one in the middle is DSC switched off, that's the traction control The "lamps" surrounding your car door warning are headlight and tail light failure warnings.
Tip petrol all over it and then light a match, all warning lights go out and give no futher trouble.
clark20,
Feb 28, 10:11pm
I thought they were globes! Lamp is the whole unit, as in headlamp.
gsimpson,
Mar 1, 4:43am
Multiple apararently unrelated warning lights can be caused by a battery on the way out or poor connection to the battery at the terminals.
