Dissassembly guide for 1998 odyssey?
davidgb, Feb 24, 10:16am
Had jewelry fall in vent. Anyone has a dash disassembly guide for 1998 odyssey!
kazbanz, Feb 24, 10:32am
david I take no joy in saying the odditty is not funn to remove the dash from.
BUT before you rip it all to bits -which vent ! Have you looked under dash to see if you can just rip the plastic"tube"section-
under the vent out
mugenb20b, Feb 24, 12:39pm
How!
msigg, Feb 24, 1:30pm
vacuum cleaner.
davidgb, Feb 24, 2:35pm
have tried vacuum but no luck. earrings placed on dash and slid into the defogger vents and moved around in there when car was driven.
bigfatmat1, Feb 24, 3:02pm
Those vents at windscreen will be attached to dash is dash would need to come completely out to access. If they have travelled further then heater box will need to come out and be dismantled . I would highly doubt you would find disassembly instructions. I have removed lots of dashboards usually just work it out as ya go its not hard screws can be hidden under clip on panels sometimes you need to be pretty firm with things good luck
