Toyota Corolla temp gauge
frank1, Feb 9, 6:25pm
1991 model 1600--temp gauge reads zero when driving,then creeps up to just below 1/2 way,accelerate then goes back to zero,and flucurates
Temp sensor prob?
Thanks
franc123, Feb 9, 6:34pm
More likely a bad connection to the sender, clean and retension the terminal. Have seen this before on Toyotas with the single wire temp sensors.
andy61, Feb 9, 7:00pm
Could be the thermostat requires replacement,easy to replace.
jmma, Feb 9, 7:04pm
How long have you owned the car?
What is the radiator condition?
frank1, Feb 9, 7:38pm
Radiator is ok(fin wise),but coolant is brown,and have just bought the car.
Will check connection to sender and flush cooling system
msigg, Feb 9, 7:41pm
No as above will be the thermostat. Simple.
jmma, Jun 27, 4:58pm
Will be partial blocked radiator and no thermostat.
You on the right track, a good flush, new thermostat and inhibitor. Then another 200k of trouble free motoring (o:
