I have a Suzuki pan anyone know what year these are?
also I am having some trouble starting it I spray crc into carb it turns over but it just wont start any ideas?
usually it would start with the crc for a moment then dies but now nothing.
056cripz,
Nov 19, 10:57am
at least I assume it is a pan? going by the stickers on the plastics.
Nov 19, 10:58am
well do you know the basics ? like testing correctly for spark.
056cripz,
Nov 19, 10:59am
not really if i'm rite you take plug out by leave attached to coil and turn over and check for a spark against frame or something?
Nov 19, 10:59am
if you use google there is no such thing in search results as a suzuki pan. What is it a vespa like scooter or what.
056cripz,
Nov 19, 11:00am
yes just a normal moped scooter 49cc I googled it aswel and came up with nothing
Nov 19, 11:01am
post a immage of it or a few of it on iforce and give link here. i tinkered with mopeds from when i was 10 years old till 17 when i was looking forward to buy me a diesel car a long time ago now. http://iforce.co.nz/
noswalg,
Nov 19, 11:07am
Enter your plate number into carjam, it should tell you the model.
m16d,
Nov 19, 1:10pm
Spraying CRC into the carb won't help it to start. probably just foul the plug.
056cripz,
Nov 19, 3:47pm
Maybe its the plug then I aint had bike long and deregistered so no plate ive looked for vin but appears to be in chinese the plate on frame. I'll have another look at plastics maybe its not pan maybe I read it wrong, is there any site that can give me a list of all suzuki mopeds ever made?
cabrio1,
Nov 19, 5:39pm
Put a little bit of petrol down the plug hole, screw the plug in and give it a kick. If it fires up carbs prob blocked.
cabrio1,
Nov 19, 5:54pm
It's not a Suzuki van van is it? Google that and see if it's one of them.
If it's been a while since it was going clean carb out should be a drain screw on the bottom of fuel bowl. Check to see if fuel will run out when you open it .If not than carb will need to come off
ambo11,
Nov 21, 6:04pm
2 stroke? Maybe low compression?
056cripz,
Nov 23, 9:29am
Not the 83 model and not sure if 3 stroke or 4 im guessing 4?
if it is a 4 stroke then you should have engine oil in the engine sump.
