Air conditioning works but the fan does not.Does the dash have to come out for a new blower & if so what is approx cost. Thanks
gammelvind,
Mar 13, 6:07pm
It cost our company, fortunately not me, I just drive the thing, $600 plus gst. Dash is largely dismantled.
Edit to say we have done it twice in 300,000 km.
Mar 13, 6:35pm
you want to know the exact fault befor you start pulling things apart wiring diagram and checking curcuit and fuses would be the way to start 2005 most likely you can comand the fan on with a factory capable diagnostic scanner .
alski2,
Mar 13, 6:58pm
Thanks An auto sparky quoted 16 hours labour to pull apart dash.
jmma,
Mar 13, 7:00pm
Get a quote from the Ford dealer, their hourly rate may be dearer, but they probably can do it faster (o:
Mar 14, 7:06am
yes possible and they might find something else to be causing the problem with there oem scanner . i doubt a sparky has a ford factory level scanner
May 1, 8:46pm
make sure you take it to a competent dealer who looks in there computer for possible TSB and knowen fixes like flash-upgrading software in some cases along with a new component to not work it to death with the way its programmed to function again.
