Ae92 corolla
steptoe37, May 18, 8:20pm
Wife's 1990 4af corolla intermittently runs rough to point of stalling
You can then restart and runs fine I'm thinking coil problem that is all I can think of any other suggestions welcome .
jmma, May 18, 8:23pm
Shit in the carb, that will fix it (o:
You could have a look here, maybe split Vac tube
http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528006f1cc&CJPID=3193631&cmpid=cj
steptoe37, May 18, 8:37pm
Carb all good have given that good clean out but will check for vac leak thanks
countrypete, May 18, 9:23pm
Look at the main wiring. Could be a frayed wire touching something and earthing out. Happened to me.
aredwood, May 18, 10:50pm
While your considering ignition issues - how old are the spark plugs and leads? And if it only tends to run rough at idle - check the head gasket.
henderson_guy, May 19, 6:00am
I'm pretty sure that shitting in the carb will only create more problems, if nothing else, it will make your vehicle run like crap
inkapuka, May 19, 6:17am
Just ls swap it hahahaha
intrade, May 19, 7:36am
if you cleaned the carb then the gunge from the carb will be on the sparkplugs afterwards
poppy62, Jan 24, 11:57pm
Hi mate! can't believe I'm going to make a suggestion and possibly solve a problem in your specialised field. I May out do the resident Corolla Guru on this one. Just off to bake a cake with a lot of Humble in it. Everything ok in the soggy south?
