Something a bit different. Honda motor in a Mini
poppajn, Jan 4, 9:39pm
Chap here doe's them beautifully, tilt front, road car's
ignition328, Jan 4, 11:20pm
The axles are towards the rear of the motor, the H22 is also an all alloy block so the weight is probably pretty good.
tony9, Jan 5, 7:36am
Not an uncommon conversion. Subframes to suit are available off the shelf.
Real fun happens with one at each end.
apollo11, Jan 5, 6:32pm
What about a big bike motor? Something like a kawasaki 1400 or a Hayabusa? Then your weight would probably go down.
brapbrap8, Jan 7, 5:32pm
A chap in Auckland has one with a K24 and 4wd running gear from a CRV in his. 2.4L VTEC 4wd mini goes pretty quick.
tony9, Jan 7, 6:04pm
Or you can put a BMW K1 head on the A-Series engine.
http://www.dep-o.co.uk/features/ultimate-a-series/
And put one of those at each end of a mini.
richardmayes, Mar 14, 5:15am
You can buy a subframe to fit a Honda B series in the front (where the engine belongs) off the shelf in the US. Apparently it's a slightly easier fit in a Clubman than in a round nose Mini.
IIRC Mendoza motorsport in Upper Hutt were making similar that were able to be complied here. ?
I saw one of these cars complete at a British Classics show. with a DOHC VTEC b series engine there's not much room left in the engine bay for anything else!
