I got a flat the other day and needed to put on the spare. Someone (probably me) must have over torqued one of the wheel nuts last time so when I managed to get it off, half the stud thread came out with the nut. I had to get the spare on, so I just forced the issue and mashed the nut back onto the mangled thread. It felt horrible and I'm pretty sure when I come to take it off again it will just shear the stud.
So could someone tell me what size the wheels studs are in a '92 Isuzu Bighorn. Google has failed to uncover the info that i need and I'd rather not pull them out until I have a set to replace them.
Thanks.
rob_man,
May 6, 8:15am
Ripco or similar should be able to supply the correct ones from your chassis number. Get on the phone.
mack77,
Feb 13, 12:09am
It should be M12 x 1.5, although I don't know how long it needs to be.
