Number plate light ? Approach it from the other side
Sep 26, 8:20am
big hammer-plastic smashed prob solved.--its only a pug. being serious it LOOKS like the screws come from the other side of the mounting
saxman99,
Sep 26, 8:32am
That notch in the bottom looks for all the world like a place to insert a screwdriver to lever it off. But I bet it isn't.
ema1,
Sep 26, 8:41am
They are a snap fit unit troggie, you insert a slim screw driver into the hole on the drivers side of the lens and you spring it out of it's holder/retainer. Bulb inside is a cap less type from memory? You will most likely find a you tube instruction online, most things are online these days mate. cheers.
I'd have to use a French gros marteau to do le job.
ema1,
Sep 26, 11:50am
That's OK troggie, think you've got to think French to deal with some of the quirkiness. Saves the expense of a couple of screws I suppose?
trogedon,
Sep 26, 4:29pm
I got the wof. The mechanic said as above re flicking the lens off. Why didn't he tell me in the first place! Grr. On a brighter note - a one year wof. Never had one of them before. How to remember?
tintop,
Sep 26, 6:01pm
You get a wee sticker that goes up on the top right of the inside of le/la windscreen ?
ema1,
Sep 26, 7:53pm
L'autocollant de WOF va sur le coin supérieur droit du pare-brise et troggie brillante maintenant vous savez comment la lampe est démontée. Acclamations de ema1
Translation The WOF sticker goes up on the top right of the windscreen and brilliant troggie now you know how to dismantle the lamp. Cheers ema1.
2sheddies,
May 3, 12:33pm
Can't be too hard on your spannerman there trog. at least he showed common sense and didn't send you away without the wof for such a minor fault. some would make you come all the way back for a recheck.
