Trailer LED dim?
ambo11, Feb 28, 5:19pm
The left indicator lights on our trailer have suddenly become very dim, all individual LEDS are working,but dim. as in dim enough to not see in the daylight. The brake and tail on the same side are still bright. I looked at wiring connections on both towing vehicle and trailer, (and the other trailer is fine hooked up to the van) but all good and clean. So my question is, do LEDs go dim when failing? Earth must be good as other LEDs are bright. Seems weird. chinese LEDs of course but wondering if they have got moisture in and have failed? Anyone else had this problem? Cheers
franc123, Feb 28, 5:27pm
Yes quite likely. Have seen corrosion of the circuit board cause that issue.
clark20, Feb 28, 5:31pm
Still check the earth, never assume.
Then go buy some real ones at BNT
skin1235, Feb 28, 6:05pm
the cluster of side lights will have a track to the earth, as does the cluster for brakes, and the cluster for indicators
the earth peg maybe making perfect contact but if the track is dicy the led's will be dim
bigfatmat1, Feb 28, 6:14pm
Check the power wire may have vd
mrcat1, Mar 2, 8:27am
VD? it may have a Venereal Disease? well I suppose the OP did say its F*&ked.
mrcat1, Mar 2, 12:23pm
Really? is that really what he was referring too? No I don't think so, it had nothing to do with any voltage droop.
tony9, Mar 2, 12:40pm
LED's are constant current devices, with a power supply capable of a wide range of input devices. Most likely the sub-module for the left indicators is faulty. There will be a different sub-module for each "bulb" (which is really a set of LED's in series). Most likely you will need a new module, which may mean a new lamp set.
clark20, Mar 2, 4:22pm
A lot of the cheap ones are "dumb" , no supply regulation, thats why they are cheap
unideck, Mar 2, 5:39pm
Thats half the problem mate, we only carry the Alko range here now, made in NZ (Hamilton) under the Narva range. 6 to 30v brand new pair 125x125 lights $30 - The "others" were coming into NZ at $15.00 a pair, gets what ya pay for aye
clark20, Mar 2, 5:44pm
Really? I though the only ones made here are Hella
Do you get called on by Wern?
unideck, Mar 2, 7:25pm
No, I deal direct with Alko ;)
unideck, May 21, 10:43pm
I understand the Narva is under licence but hey, could be wrong. I do buy 99% of my trailer parts here, steel, ply, lights etc. Suspension is ex UK (as in Alko)
