94 suzuki swift with surging chugging ?
leelee79, May 28, 6:10pm
what could it be ?
jmma, May 28, 6:14pm
When does it surge and when does it chugg?
More info.
leelee79, May 28, 6:29pm
when driving , lol
jmma, May 28, 6:30pm
How many km's has it done and when was the last service done?
leelee79, May 28, 6:44pm
160 km and dunno when serviced
jmma, May 28, 6:56pm
Umm, think we have found your answer then (o:
leelee79, May 28, 7:01pm
don't bother .
jmma, May 28, 7:03pm
Don't drive it, problem fixed. :oP
snoopy221, May 28, 7:09pm
Tis on rag week needs a plug-or 4 as in NEW spark plugs K
jmma, May 28, 7:17pm
Sounds about right (o: Lol
countrypete, May 29, 4:52am
Leelee, I see you deleted a message and can guess what it may have said. You came to this forum for help, and all you got was sarcasm and silly comments.
The first thing you should do is give the car a basic service. Start with checking and cleaning the air filter to make sure it's not blocked, replace the spark plugs, and quite likely the HT leads if they have never been done (and quite likely they haven't). Check that the exhaust is not blocked either at the manifold, or through its length. I'm pretty sure these are carburetted so check that the choke isn't sticking, as this will cause the car to run too rich and could well cause chugging, surging.
If these are things you are not confident doing yourself, take it to a reputable garage and ask their advice. They are pretty basic cars mechanically, so it shouldn't be too big an issue Good luck
leelee79, May 29, 5:05am
thanks country pete, helpful advice , will start by checking those things ,
kazbanz, May 29, 7:23am
Leelee- can you qualify that the car is a 1994.?
if it is then its a holden barina with a Suzuki badge.
Theres a few causes of the issue you describe if it is the 94
Pete covered most of them off. But the foul weather we have had lately will also be a possible cause. Ie water in places it shouldn't be
jmma, May 29, 7:49am
Not sure how you arrive at this? I was trying to get more info that wasn't being offered, also suggested the first thing you did, "A Service"
tamarillo, May 29, 1:10pm
Hey Kaz,, isn't it the other way round, that the Holden was a rebadged Suzuki up to then? Around that time it switched to being a rebadged Opel I think.
Whichever, op, your car needs a full service, only then, if problem remains, can you try to diagnose it as it's more than likely it simply needs tune, plugs, etc.
kazbanz, Aug 31, 12:11pm
probably the case but Im trying to establish if the OP has the correct year.
Im betting on water in places it shouldn't be
