Or if you have any advice on getting one of these off?
cheers k
bjmh,
Dec 9, 2:42pm
the bearing puller you show probably won't do it ,I would put a rag down the tube . break out the inner race /rollers cage . then run a weld around the actual bearing race,when the weld cools just pluck out the bearing with a pry bar.
bjmh,
Dec 9, 2:44pm
had another look at your picture,you sure the housing doesn't unbolt from the diff housing ?
mrcat1,
Dec 9, 5:52pm
Sykes or Toledo do a bearing puller like that shown, go to a good engineering shop instead of the likes off Super Sheep.
rachyd,
Dec 9, 7:47pm
I think there are bolts inside diff head to undo before the axle will come out then get them on a press
michelle322,
Dec 9, 8:01pm
I would go to a Engineering shop with a measurement of the bearing, Show them that photo of the bearing,Tell them make a slide hammer something like in photo.And also get them to make a tube with plate on the end to drive the new bearing back in.
Presumably a collar and that is your pic?-I.E. exposed thread-presumption is collar removed axle removed and nuts done up again. (Similar to a DANA-but no obvious ability to space set axles)
You do realise a kiwi number 8 wire speights drinkin houer would remove the diff head and use a long steel rod and a sledgehammer? However a bent rod and a weld WILL shrink the bearing once the rollers have been removed and it WILL fall out-K
poppy62,
Dec 9, 8:16pm
Can you not get a 3 legged puller with the legs (inverted) facing out, in the bearing? The rollers look like they are well retained and held by the retaining ring and bearing face. I'd try the 3 (or 2 ) legged puller crank it up and apply some heat around the outside of the housing.
kwm30,
Dec 10, 2:55pm
snoopy21, c clips retain the axle in the spider gears in the rear diff. we tried to jerry rig up a pivot puller as seen on the photos, not much success. A 3 prong works (grabs the back of the bearing)but cannot fit anything in between to give it something to push against. Your suggestion of a weld might work. will give it it try. thanks. its a dana 35 diff on a grand jeep Cherokee. dam 6month warrants. cheers for the advice guys.
k
mals69,
Dec 10, 3:33pm
Had same need - alibaba & alibabaexpress
panicky,
Dec 10, 3:36pm
Did you fail a WOF on too much end float?
kwm30,
Dec 10, 3:40pm
noisy bearing on the drivers side rear axle. can you believe it. the axle on which the bearing rides on is a little pitted, but not severe. mals69. would you like to rent out your puller for a dozen or two?
panicky,
Dec 10, 3:44pm
I wondered as hey are basically a 1950's Chev truck design from the dark ages and have end float new. I have seen a number fail warrants, but that is how they are.
lookoutas,
Dec 10, 5:22pm
You're the man.
NZTools,
Dec 11, 7:20am
You called? ;p
mm12345,
Dec 11, 7:40am
Just to clarify, is running a weld around the shell so that when the weld cools it shrinks back a bit, hopefully loosening the shell a bit so it pops out easily? I guess a seal goes in there over the bearing, should something be used to protect the surface where the seal fits from splatter, or will it probably be okay?
mals69,
Dec 11, 7:59am
Sorry for not being clear but never got round to buying one was a bearing in motorbike hub so managed to knock it out from otherside. Alibaba does have them, guys were selling them on here for 3 times the price at the time. If you youtube removing blind bearing etc there are plenty of videos of guys removing bearing with bread - I kid you not.
lookoutas,
Dec 11, 3:47pm
You'd need a fair bit of bread to chock that hole up!
You could slip a bit of exhaust tube in there to protect the surface if running a weld.
mals69,
Dec 22, 2:24pm
Bread cheap
gmphil,
May 18, 11:04am
air saw split bearing !
