I have a 1990 ford festiva 1300 mazda B3- and for the last cpl of months shes had a rattle when moving off from stop position or almost stop at very low revs.It doesnt do it at any higher revs just on take off-forward or reverse.I thought pinking-like timing has changed?but usually thats under full throttle-this is not.Maybe the cam belt has worn and slipped a tooth but then youd have valves touching pistons-bang bang and its not doing that.Mmmm?Any ideas?
muzz67,
Apr 8, 11:39am
prob the exhaust is touching something somewhere.
ant72,
Apr 8, 11:51am
forgot to mention-its auto.will check that out muzz but it sounds like the motor-i put the hanbrake on and in gear and its from the motor as i start to rev it?
ant72,
Mar 24, 2:49am
Put my foot on the brake-lightly revved-rattle-checked exhaust-no movemont or rubbing etc.Car doesnt do it when outo choke is on -only when heated up-put foot on brake-in gear-lightly tapped accelerater-rattle-left handbrake on in gear-less than 500 revs-noise from cambelt cover-perhaps tensioner bearing?.must add-car no rattle at normal revs only on takeoff.Mmm
