Car radiator cap not hot
ppgirl1, Apr 30, 3:49pm
Driving to work this morning and my temperature went way up to hot for bout 5 seconds then dropped back down to normal.(half way). Stopped and checked water. Noticed radiator cap was still cold. as I started to take cap off it started to heat up as the water started coming out. What could the problem be. Thanks
wind.turbine, Apr 30, 3:55pm
stuck thermostat?
ppgirl1, Apr 30, 5:21pm
Ok. Thanks. Will get a new one
jmma, Apr 30, 5:38pm
Hang on a minute, what is the make, model and year of this vehicle, milage also a help.
Has anything been done to the car recently?
ppgirl1, Apr 30, 6:06pm
2001 VX holden. 180,000k and nothing done to engine recently
monsieurl, Apr 30, 6:57pm
Sounds like a dead thermostat, best way is too feel the lower hose and top hose after its warmed up and if one is cool and other is hot, that's your issue.
sparkyz, Apr 30, 7:19pm
. or it was just the temperature gauge throwing a wobbly!
monsieurl, Apr 30, 7:26pm
Doh. Yeah good points!
kazbanz, May 1, 7:39am
There ya go--all the info together
IMO in order of probability
1)theres an issue with the gauge and its first time you've noticed it fritzing.
2)stuck thermostat.
3)temp sender unit faulty
4)blocked radiator.
bjmh, May 1, 7:43am
vx. check the radiator cap hasn't come apart. common fault . check it cold.
tony9, May 1, 12:01pm
A modern (less than 40 years old) thermostat will fail in the open position.
Looks like low water level to me, have you got a slow leak?
ppgirl1, Feb 18, 3:45am
So I got home tonight and temp was ok, top and bottom hose, radiator and cap all nice and warm as well. Just seems all normal
