180 deg F thermostat
rambler_man, Jul 30, 12:18am
195 or 180 degree thermostats
tony9, Jul 30, 12:20am
For what?
Different vehicles have different temps, for a variety of reasons.
Best one is the manufacturers spec, if the vehicle is standard.
rambler_man, Jul 30, 12:34am
In an old school v8 says 195 or 180 deg
tony9, Jul 30, 12:36am
Then use the warmer one, particularly in this weather. It will help to get rid of condensation in the oil.
loud_37, Jul 30, 1:34am
Make more HP with 120 deg water temp
ceebee2, Jul 30, 2:39am
180 is fine.
nice_lady, Jul 30, 2:52am
Subtract 30 deg and divide the result x 2 for Celsius.
180 F - 30 = 150
150/2 = 75 C approx.
ceebee2, Jul 30, 4:48am
180 F = 82 C (Most older vehicles run with.)
tony9, Jul 30, 4:49am
Don't see how that is relevant to OP.
And what are you trying to do?
To convert Fahrenheit to Celcius, subtract 32 and multiply by 5/8.
rambler_man, Jul 30, 7:08am
Use to run 180 deg F from the engine over haul, the service book says 195 deg F so, a few years on carried out a tune up, put in a 195 deg F, BUT now have noises that weren't there before using the 180 deg F stat. Noises in Engine, running In cold weather before the thermostat opens and the hot engine running in cold weather.
curlcrown, Jul 31, 6:03am
Green
the-lada-dude, Jul 31, 5:49pm
If it's any use, . 84* c seems to produce the best HP
rambler_man, Aug 2, 12:50am
I thought so, 195 deg F good back in the day of manufacture 1964, Slightly different petrol than what we have today?
esky-tastic, Nov 7, 10:03pm
Higher temp generally equals more efficiency - but increases the chance of pinking (your timing might have to be adjusted to suit.)
