Hi I was wondering if this has happened to anyone else and if so how did they fix it.I have just had a new battery fitted to my Swift and although everything works fine after I turn off the ignition I get three beeps .There is no dashboard indication that anything is amiss, I have replaced the battery in the keyfob, google tells me the bonnet isn't closed properly but that seems ok.
Aug 12, 1:51am
If bonnet shut what about tailgate? If Google is correct.
pommyjohn1,
Aug 12, 1:56am
no boot is ok
motig,
Aug 12, 7:38am
OK I'm not a mechanic but is there a switch or something for the bonnet that perhaps is stiff or faulty. Dirty contact ?
kcf,
Aug 13, 3:12am
Do you have a Sony headunit?
Unless you've turned it off (as a feature) they beep at you after you turn the car off.
It might have been previously switched off, but has returned to default settings with the car being unpowered for a duration.
kingfisher21,
Aug 13, 4:38am
This is more than likely smack on the money.
saxman99,
Aug 13, 3:57pm
Pioneer units do this too.
pommyjohn1,
Oct 28, 12:01pm
Thanks kcf you were spot on , this was the problem many thanks
