1997 UK Ford Escort 1.8 zetec.I had to swap
tshop, Sep 1, 4:04am
RE: 1997 UK Ford Escort 1.8 zetec. I had to swap the car's ECU and the key doesn't match (Car wont Start). what app or software tools Does Fix it? thanks Pete.
intrade, Sep 1, 6:36am
well Why did you swap the ecu?
also is this ecu one who can be opened up easy?
intrade, Sep 1, 6:42am
there is 2 options the cheapest is if the ecu is not a nightmare to open.
You transfere the immo chip from the old ecu via soldering,
option 2 is with expensive tools who can hack the pincode or somone who can virgin the Ecu. if its a virin you can then programm the pin from the original ecu. provided you acturly have that.
Otherwise you need to have both pin codes hacked as you cant log on to a a ecu with a wrong pin obviously.
So question is why did you chage the ecu to start with?
Swaptroning . guessing or actuarl reason.
snoopy221, Sep 1, 6:45am
Maybe zee intelligence 101 app that sorta negates get the key with the ECU.
Thus saving the reprogramming?
ozz1, Oct 10, 11:43pm
i would have swapped it for a 6 pack of beer.
