Coolants only for Ford
intrade, Oct 23, 11:51am
Worse nightmare then vag coolants but similar as in I told you so.
https://youtu.be/o1pz05j4uWE
intrade, Oct 23, 11:58am
Red nuolon Red is a dexron clone as it meets gm and Ford explains where it fits in to the picture of compatible to Ford. Only universal fluid is breake fluid dot 4 is for any car the same fluid , unless you get some marijuana smokers who add atf in the system because that's the right stuff while in lala land.
intrade, Oct 24, 8:57pm
bump . No one have a ford ._ and also
WHO KNOWS WHAT TOYOTA USE BECAUSE TOYOTA DO NOT LIST ANY INFORMATION WHAT THE RED FLUID CONSIST OFF.
For VW i found G12 from valvoline as concentrate.
i did do a reaction test with the oem toyota fluid in small dose and nothing happend mixing valvoline G12 and factory oem toyota red coolant.
3tomany, Nov 2, 11:17pm
Sounds like a good change. I guess my ford dealer will put it in if needed.
