2012 Mondeo Clutch Kit . Suggestions on Suppliers
eilgor, Feb 17, 3:14am
Hey Guys - looking for a 6DCT450/MPS6 clutch kit for my Mondeo - genuine part is $8400+GST - I can get from Alltranz in Auckland for $2600+GST but wondered if the community here knew of a way to get it cheaper? I've heard that LUK parts are good replacements for genuine but cant seem to find them on mr Google . thoughts and advice sought. Thanks, Alex
tamarillo, Feb 17, 4:25am
Rock auto in states are fantastic. Thinking that mondo was called fusion in states but you’d need to dig a bit to check same clutch kit.
https://www.rockauto.com/en/catalog/ford,2012,fusion,2.5l+l4,1501984,transmission-manual,clutch+kit,1993
franc123, Feb 17, 5:08am
You need to be getting access to the Ford part numbers for what you need before going any further, obviously a written quote from an agency is the best way to get this. They already know that nobody is going to pay the value of the entire car for a clutch kit.
It's a no brainer that you should be sourcing these parts from overseas.
apollo11, Feb 17, 5:11am
Ouch! Eight and a half grand. And you can break down your old clutch for the precious metals contained inside.
sw20, Feb 17, 5:14am
This isn’t a manual trans car, this is the wet clutch Powershift DCT.
gph1961, Feb 17, 5:36am
boo who
blub
poppy62, Feb 17, 7:16am
Give Neil a call at Auckland Clutch in Kingsland.
gazzat22, Feb 18, 3:17am
Wouldnt it be worth investigating the price(s) of a new or reconditioned one.?
tamarillo, Feb 18, 3:49am
ah! RockAuto may not be able to help then - I am guessing the fusion didn't use it.
ebay https://www.ebay.com/itm/MPS6-6DCT450-Clutch-Kit-with-New-Front-Cover-Position-Bushing-For-FORD-VOLVO-/164355039315
trouser, Feb 18, 4:13am
helpful. Prices in NZ can be stupidly expensive compared to overseas. That clutch pack can be had for about $2k overseas.
clark20, Feb 18, 5:38am
esprit, Feb 18, 7:53am
Had my 6DCT450 clutch replaced, used the Alltranz clutch kit. Needed a bunch of stuff doene was about 6k all up including labour.
gph1961, Feb 18, 8:01am
ouch
evotime, Feb 18, 8:13am
there was a few that went to the wreckers with power shift problems in my ford days.
Don’t forget to add the cost of the fluid and filter to the cost it’s not cheap. Then the relearn on ids so scan tool charge plus labour.
From memory the complete box was about 12-13k! So that’s not going to happen.
But yeah there’s a few on the Uk equivalent of trademe for about a thousand £, + freight +gst + fluid/filter + fitting + scan tool even then your still going to spend a fortune to hopefully fix it if it doesn’t also need a mechatronics unit.
Yours isn’t the 1st and won’t be the last unfortunately.
gph1961, Feb 18, 8:34am
stick it on the mortgage
esprit, Sep 13, 3:00am
The gearboxes are actually quite reliable. Clutches last about 200,000km. And when replaced will do another 200000km. There is a fault where sometimes as the clutches get old the brittle plastic spring damper ends on the flywheel can break up and clog the valve body causing an expensive malfunction as the box nmand valve body needs to come apart to clean it out. That kind of failure isn't mega common but can happen.
