driver's window stop halfway up in hot weather left a few minutes goe's up. No noise (grinding etc) good when cold weather.
bigmacnfries,
May 6, 8:58pm
Cool story
curlcrown,
May 6, 9:14pm
Sounds like it is getting stuck and regulator motor is cutting out to prevent it from burning out, hence will work again a few minutes later. Try cleaning out the rubbers and when dry apply some graphite powder.
budgel,
May 6, 9:18pm
If you can still hear the motor trying,check the tracks it slides in. Maybe a little silicone spray in the tracks would help. If its the motor that cuts out, you will have to check its electrical connections.
May 7, 12:16am
same spot every time? likely motor is getting old and hitting resistance. as curly says slean up the tracks and see if that fixes it
Aug 11, 5:52am
2004 should unlikely be electronic , knowing toyota who used dinosaur tech for as long as possible. So its most probable a mechanical issue if its in the same spot. if it was 2021 model it could be faulty door computer but not on a 04
