Falcon Wipers
v8_mopar, Aug 2, 3:41am
Normally I would think it was the stalk connections but I have heard with the fg if the blade stops half way up he window its more likely to be the motor.
Anyone got any input on this topic?
They work as should if they are on or off but if they are on time delay they stop anywhere they like.
poppy62, Aug 2, 4:12am
Faulty intermittent relay!
v8_mopar, Aug 2, 4:17am
That sounds promising. Were would the relay be hiding?
franc123, Aug 2, 4:32am
Wipers will be fully controlled by the BCM on one of those I'd have thought. I would suspect motor too, it would pay to check with Ford agent to see if that fault wasnt covered by a TSB or maybe even a recall action. There could be an upgraded part involved.
v8_mopar, Aug 14, 4:51pm
No ford fault so I just put a second hand one in and all good now.
I really shouldn't complain as it only didn't work right when it was raining ;)
3tomany, Dec 7, 6:57pm
So caused by moisture on the screen?
