Nissan ga15de
xs1100, Sep 11, 12:40pm
cutting out and missing,have replaced spark plugs/fuel filter/air filter but just seems to miss under accelaration anyone got any further ideas for these motors plse
franc123, Sep 11, 12:44pm
Assuming the HT leads aren't shorting out the air flow meter is probably dying, they develop dry solder joints inside them, loads of threads on this subject.
xs1100, Sep 11, 4:09pm
thanks franc appreciate that.will try and search now
xs1100, Sep 11, 6:21pm
anyone else plse
frank1, Sep 11, 6:36pm
franc123 is right--air flow meter--,guess it stops at idle!
had my daughters car airflow meter repaired--cost $160 from memory.
Done by auto electrician--same motor.
xs1100, Sep 13, 7:54am
Umm no frank1 it doesn't stop at idle only sometimes under accelaration. Will get that checked out, many thanks
morrisman1, Sep 13, 8:15am
if your fuel pressure is low it could also exhibit some of those symptoms. Check the system for leaks
xs1100, Sep 13, 6:31pm
was driving along the other day doing about a 100 and it just completely day as in all the electrics,rev counter and then just sparked back into life and carried on
morrisman1, Sep 13, 6:35pm
odd. Possibly a dirty contact on a main connector!
lilly105, Oct 24, 12:51am
Can't offer any advice but the GA15 (Pulsar) is far better than the QG15 (Sunny)!
