Hiace with 2 batteries
bus222, Sep 30, 11:14am
could anyone tell me whatthe reason is for a hiace van to have 2 batteries in parallell,thanks
mechnificent, Sep 30, 11:20am
x1
So it doesn't get a flat battery as easily. The two batteries have more capacity, so they will run accessories for longer.
It may have been a camper or a mobile workshop or something like that.
bus222, Sep 30, 11:32am
x1
thanks for that,
the_don_61, Sep 30, 12:56pm
Seams odd.
My Hiace has two battery's.fitted up the same as campers and telecom vans.
Power charging lead from Alt goes to a splitter box and then a lead to each battery.
Having it the way you have would be a waste of time, unless your batterys are stuffed.Unhook 1 and see if van still starts!.
mantagsi, Sep 30, 8:31pm
So what you are saying is that both your batteries are also in parallel.!
phillip.weston, Sep 30, 8:38pm
diesel hiace! my diesel Delica van had two batteries in Parallel. Diesel engines generally need a large amount of power to crank over the engine, and that power is provided by one large heavy duty battery or two smaller batteries.
scarey65, Oct 1, 4:30am
but having two batteries its always gonna cost you 2xouch!
bm4, Oct 1, 5:45pm
24v start!
v8_mopar, Oct 1, 5:56pm
no they are + to + (12v) not + to - which would make it 24v
the_don_61, Nov 30, 2:52am
I sopose they are in a way, but if lights in van die and tv stops working battery is flat.But std factory battery still starts the engine. engine recharges both.
