Installing a rear window
digga7, Oct 10, 10:39am
Hi all, I've got an old Toyota Crown that I'm slowly doing up. Some things I can do and others I have no idea of where to begin.
Currently the rear window has been removed, it's in good nic and the surround has been cleaned and sanded.
Pretend that I'm an idiot and never done it before.Infact, don't pretend.
In laymans terms: What will I need in order to do it! Does anyone have any tips and pitfalls that I should be aware of before I start!
Any advice, is much appreciated.
twink19, Oct 10, 11:04am
put rubber on window glass, insert piece of thick string into rebate in rubber, lay over opening and press down from the out side while pulling the string out, this will allow the rubber to peel back and rfit over the metal of the body.
socram, Dec 22, 11:09pm
Just make sure the rubber isn't damaged or brittle.Pro's use a sealant afterwards too, otherwise you may find annoying leaks.If you are struggling, take the screen and rubber to a screen fit place and ask for a quote.
