right i got a window winder and it decides that it needs a hand to get the window closed but it will open very easy i have replace the window control and its doing it with the new 1 how to fix
andrea_w,
Nov 18, 7:51pm
Clean and lubricate the window runners
jasongroves,
Nov 18, 7:54pm
Ok, can you please type that out again! This time, add some punctuation, the year of the car and a more detailed description.
jono2912,
Nov 18, 8:36pm
Missing nut/bolt, broken runner, or maybe a worn motor.Oh. Is it electric!
whiteboy007,
Nov 18, 9:34pm
yes it electric and its a 92 mazda famila gtx as it is i find it very hard to type and spell so other people got i i tryed to type it out as simple as i possalby could i even pulled it apart and checked the little ball runners and still no better the other one that i got off mate it worked in his car fine but no show in myne
jono2912,
Nov 18, 9:43pm
Did you replace the switch, or the motor!
tmenz,
Nov 19, 5:31am
Do you have any recommendations on what to use to lubricate the runners!
whiteboy007,
Nov 19, 7:46am
motor
Nov 19, 11:24am
whiteboy. 1) wash the window with windowcleaner 2)put the window down and lube the track with silicone spray. -operatte the window a couple of times. try loosening all thetrack mounting bolts about half a turn then wind the window up. Tighten them back up a bit.
whiteboy007,
Nov 19, 12:45pm
cheers will try that
rob_man,
Mar 17, 8:05am
Yep, there should be a slotted hole in the mounts somewhere to adjust the angle of attack for the glass in the channels. A bit of trial and error should find the optimum position.
