had a second hand garrett gt3540 and it blew on monday, we thought it coulda just been on its way out caus we didnt really know previous history, and been on for half a year or so on this car doing drifting events and working fine, so we got a new one on wed and fitted it, done less thans a hours running and its seized on us, before we started it we cranked the engine over and had good amouts of oil flowing, left it idling before boosting to let oil flow through, its been properly tuned and checked the plugs and its hasnt been running lean.any ideas!
pollymay,
Nov 21, 8:36pm
Proper pressure to the oil feed is required, a freely draining oil drain and hooking the turbo oil feel and drain up the right way helps as well as the correct clocking of the turbo.
peril787b1,
Nov 21, 9:56pm
Running lean has zero to do with the turbo seizing. It's probably caused by incorrect oil feed or drain (as has been noted).
Nov 22, 5:45am
problems are no1 incorrect oil-lubrication-pressure- no2 forgein objects and no3 wear and blockage due to turning it off when redhot baking the oil solide in the charger - http://www.turbo-power.com/problems.html
fordcrzy,
Nov 22, 7:51am
is the GT3540 a ball bearing turbo! If not then using a BB oil feed banjo will restrict the oil too much and seize it.
jamzie,
Nov 22, 8:44am
yeah was a ball bearing, someone said should be rinning a restrictor in oil line but i didnt put it in
fordcrzy,
Mar 26, 5:14pm
might have blown a seal out and jammed the shaft!
