Ed xr6 not starting!
nave12, Jan 17, 8:31am
Well problem sorted,it turned out to be the coil,although we were getting spark it was very weak so thanks for all the thoughts and queries above,cheers.
franc123, Jan 17, 10:12am
Now you've got to check the rest of the ignition system, the usual reason Falcon coils blow is because they've been overheated due to too much resistance in the HT circuit, mostly caused by burnt out distributor caps that should have been changed years ago.
mike77, Jan 17, 10:50am
Yup, plugs, leads, cap, rotor and coil, should be on the front page of every 90's falcon manual! Page 2, dizzy module.
nave12, Jan 17, 8:28pm
yeah changed the leads,plugs,dizzy and rotor,now it pulls the mean skin off a rice pudding,,eat my dust scotty ya dreamer!.
nave12, Nov 27, 6:10am
My mate had a bit of corrosion on the battery terminals so he got some boiling water and dissolved it but now when he goes to start it the engine just cranks over but won't fire,we replaced the 3 fusible links next to the battery as they were a bit wet but still no go.Could it be one of the main fuses(as in the sqaure bulky type ones) any ideas appreciated.
brokebloke1, Nov 27, 6:11am
try another battery as you maynot be getting a full 12volts to start the car.
nave12, Nov 27, 6:24am
Tried another battery but still just cranks.
brokebloke1, Nov 27, 6:36am
have you got spark ! take out spark plug and insert into HT lead and earth to motor, crank motor and see if you get a fat blue spark.
If not then maybe your coil is gone
nave12, Nov 27, 7:04am
Will give that a try.
typhoon666, Nov 27, 7:14am
Can you hear the fuel pump working in the boot they have relays under the surge tank for the radiator.
mugenb20b, Nov 27, 7:40am
Failing that, check the fuel pressure. If you have no fuel, replace the fuel pump relay with another one that looks the same (fans, air con maybe!). If you still have no fuel, then your pump may be toast.
nave12, Nov 27, 7:41am
Yep the fuel pump does its little whiirr noise for a second when the keys turned on.
kiwitracy, Nov 27, 8:02am
Should of used plain old Coca Cola!Works a treat every time :-)
mugenb20b, Nov 27, 8:11am
OK, assuming the fuel pump is OK, have you checked for spark! You haven't disconnected anything else by accident!
nave12, Nov 27, 8:22am
I will be heading over to his place a little bit later today so we will check all the above theories and see how we go,any other thoughts will be helpful also.
nave12, Dec 4, 7:00am
Tried all the above trouble shooting and changed the fusible links and all main fuses but still no go,not sure what to do next except for taking it to an auto electrician.
v8_mopar, Dec 4, 8:31am
So you got gas and spark but is the spark erratic. Could have blowen your ignition module. After marking where your dissy sits turn it both ways when starting and if it starts and runs bad its prob the module.
crzyhrse, Apr 28, 9:13pm
Tacho moving when cranking!
