Corolla Speaker fade problem
theadamsfamily1, Jan 22, 6:59pm
Help appreciated.I have just fitted rear speakers to my sons 1995 Toyota Corolla using all the standard wiring so should be simple however when you try & fade front to rear it simply works like the balance & either right hand or left hand speakers work rather than front or rear, is anyone aware of this problem & can offer suggestions to fix!Thanks
jono2912, Jan 22, 7:19pm
All I can think of is that you connected them wrong at the headunit end.
andrea_w, Jan 22, 7:40pm
It sounds like someone has messed up which speaker goes where behind the stereo. (aftermarket stereo I would assume)
You need to connect these stereo wires to the Toyota wires
(1st colour is +ve / second colour is -ve and you MUST join positive to positive etc)
F/L (stereo) White [+ve] / White-Black [-ve] --- (car) Pink [+ve] / Purple [-ve]
F/R (stereo) Grey / Grey-Black --- (car) Green / Blue
R/L (stereo) Green / Green-Black --- (car) Black / Yellow
R/R (stereo) Purple / Purple-Black --- (car) Red / White
I assume you have all other wires connected properly as it turns on and the speakers physically work!
jono2912, Jan 23, 2:58am
Haha, cheers Andrea, knew you'd be along sometime to finish my work for me.
jono2912, Jan 23, 3:02am
Orrr, if it's the headunit that was factory - make sure you have wires for 4 speakers and not just 2. As I know the Camry was standard with 2.
jono2912, Jan 28, 12:07am
OP did you figure it out!
