Hi there I have a nissan terrano td2.7, Battery good but very sluggish when turning over to start. My thoughts were starter motor problem. Had this identical problem 2 years ago and replaced the starter motor-good for 2 years now same problem - not sure whats going on. Any thoughts/comments appreciated .Thankyou.
Jan 17, 5:42am
what did you replace the starter with! new or secoundhand!
gadgit3,
Jan 17, 5:46am
Bad battery. Bad earth strap. worn brush in starter (cheaper to rebuild in most cases)
wfl1,
Jan 17, 5:54am
It was second hand socould be the problem,Will check the earthing as well.
pup2,
Sep 26, 1:53am
Remove starter, hand over to sparky who will replace bearings, brushes if required and clean up the armature and undercut it.
