customer with terrible sounding 1.9 diesel. runs on 3x cyl. check on net and some eng threw rods,
chris_051,
Dec 4, 5:15pm
Bullet proof engines on the whole but jeez they are noisy maybe check injection timing as a start.
morrisman1,
Dec 4, 5:58pm
if you check engine code and it is D8A then it shouldnt have thrown a rod, the later DHY engines are the ones which throw rods but even then it is very uncommon.
Head gaskets on earlier ones are composite and break down, essentially rotting and then fail. Are there any other signs of head gasket failure!
Check fuel is getting to each cylinder by loosening each of the injector pipes and looking for fuel dripping out after cranking the engine.
is it a bosch injector pump or lucas! the bosch have the "UFO" boost compensator on the top (only turbo models)
the-lada-dude,
Dec 5, 5:43am
ta every body, i heard the 1.9 petrol eng uses the same crank, block & rod'syes / no !
the-lada-dude,
May 2, 3:58am
by the way, MM have you put that car that won't stop talking thru the traps yet !
