does anyone know if they were fitted to anything other than toyota mr2 i am thinking maybe something else with a rear or mid mounted motor car/bus i need one so if you have one please let me know thanks
jasongroves,
Jan 31, 7:25pm
After some quick googling, it appears that some VWs, Hondas, Mercedes, Seat, Skoda etc etc etc have used electric pumps. They can also be purchased new from quite a few places, mainly overseas by the looks of it.
jasongroves,
Jan 31, 7:27pm
Out of interest.why not the MR2 one anyway! Would have to be the most common and easy to source.
paul271,
Jan 31, 7:28pm
4 wheel steer nissans have a pump on the rear subframes whichare easier and cheaper to get. MR2 pumps are worth big dollars now
Jan 31, 7:32pm
pretty common on modern Euros, Ford Focus, Opel Astra, Peugeot etc.Interestingly some manufacturers are ditching hydraulics completely and just putting a large servo motor onto the column and using a normal manual rack instead.
pollymay,
Jan 31, 7:37pm
This, they are effective as if you wire a dial up to them you can control how much assist they give which is handy.
I don't even run a pump on my race mr2 cause it's heavy and too expensive to replace.
matarautrader,
Jan 31, 7:39pm
My wifes 2002 barina has them I am told
roys351,
Jan 31, 7:49pm
i need it to run a 4wd hilux p/s box on a 1950 bedford running a 4.1 falcon x flo & 5 spd no room for std facon pump
rkauto,
Jan 31, 7:52pm
BMW Mini also electric PS
roys351,
Jan 31, 8:34pm
me not to flash on a computa any one know models/years of what has been sugested !thanks
jsbike,
Feb 1, 8:44am
they are more of an electric rack, and they only move the wheels a couple of deg
illusion_,
Feb 1, 9:01am
wouldnt it be a lot easier and more reliable to go "old school" and fit a 4wd hilux p/s pump with reservoir, bracket etc to the falcon motor!definitely be a whole lot easier to find one
roys351,
Feb 1, 2:05pm
it wont fit in engine bay
treachug,
Feb 1, 4:51pm
I use an electric pump from Holden/Opel Astra '98-'05 model in my stockcar. Have had no issues with it in 3-4 years of racing etc. Have a few wires but thats because they only run when engine is running so normally wired thru engine ECU. The auto sparky didnt use all the wires & we have it operating thru a switch so the pump can run without engine running & vice versa. Gives nice and light steering as well.
roys351,
Feb 1, 8:56pm
thanks are you running a box or rack!
treachug,
Feb 2, 5:29am
Running a box out of (apparently) american Ford maybe F150 or similar. Wired thru a 80amp fuse and no hassles. Using late model (V6) Commodore 120amp alternator.
roys351,
Mar 1, 9:46pm
awsome thanks sounds like it would be perfect
