Nissan Mistral
honestrader2u, Feb 4, 7:44pm
My Nissan is overheating - is fine on the flat but as soo as you climb up hills it gets hot - have replaced radiator .any other ideas - does not use a drop of water
morrisman1, Feb 4, 7:57pm
Check viscous fan is working correctly, a guy at work tried a lot of things before trying the fan. His was overheating under load ie towing up a hill.
franc123, Feb 4, 7:59pm
Thermostats and visco fan units packing up are typical on those, the latter is part of the water pump and is replaced as a unit.
woki, Mar 10, 7:16pm
Remove and check the water pump to see if the impeller has rotted off . They have a steel impeller can literally rust away . The car will behave until you start working it hard .
Get it checked , you do not want to cook a diesel engine ( very expensive ) .
